for all who doubt me about the PVC pipeing here is a 7MGTE running 443HP and 11 sec on the 1/4 mile using Lowes PVC pipeing......lol
http://www.jblmk3.com/05740b40.jpg
http://www.jblmk3.com/0503a820.jpg
http://www.jblmk3.com/0538a670.jpg
http://www.jblmk3.com/073fdd00.jpg
http://www.jblmk3.com/06cd6f40.jpg
http://www.jblmk3.com/1446ab80.jpg
http://www.jblmk3.com/1739dd30.jpg
http://www.jblmk3.com/164a97b0.jpg
http://www.jblmk3.com/6d2bc0d0.jpg
http://www.jblmk3.com/6ccbc0d0.jpg
I have a new design for intercooler pipes that have really worked well for me. It's very simple and inexpensive and can be done in a couple of hours. If you do these modifications, do them at your own risk and responsibility. I am publishing this site to help people with their Mk3s because it is one of my hobbies and I just want to share what I have learned. All the parts are readily available at Home Depot or Lowes for less than $20.00. You will need a few of the original silicone hoses off your car for the connections to the 3000 pipe and Intercooler. You will also need a piece of exhaust tubing from any parts store and you may want to pick up a couple of new clamps just so it will all be new!
***I have ran a few tests on this system with one stock intercooler and the stock turbo. I used a VDO boost gauge and two SunPro temperature gauges. With my boost controller set to 15 psi at the intake manifold (it has it's own sensor to maintain the proper setting at the manifold) and the VDO tapped in approximately six inches before the intercooler in the PVC pipe, the boost measured 15 psi, just as it should. Then with the VDO tapped in approximately six inches after the intercooler in the PVC, the boost pressure was measured again with the same results, 15 psi indicating no measurable pressure drop from the intercooler.
After this, I took the two temperature gauges and plumbed the sensor probes into the same holes that the pressure measurements were taken in (of course the holes had to be enlarged). With one gauge six inches before and one gauge six inches after the intercooler, the temperature readings were taken at highway runs in fifth gear. It should be noted that these readings were taken in fifth because there was not enough time in other gears to get a reading. On 15 psi runs and 68 degree ambient temperatures, the temperatures before the intercooler reached just under 295 degrees Fahrenheit. This is the section between the turbo and intercooler, and the hottest section in the system (and no, the PVC does not melt or deform)! At the other temperature sensor, after the intercooler, the readings peaked at slightly less than 150 degrees Fahrenheit. That is very good in my opinion, considering the heat that is put out of the stock turbo at 15 psi. I would estimate that the stock turbo is only about 60% efficient at 15 psi and would not recommend running this level of boost with the stock turbo on a regular basis. This test was simply to test the PVC/stock intercooler efficiency. I believe that the stock intercooler system is actually better than most people think. I believe that the pressure drop reported is due to the stock intercooler pipes, not the intercooler it's self These tests (mine) could be a lot more accurately done with better instruments, and are really quite crude, but I have not seen any other efforts to test the stock system. These are just my estimations, and I suggest that you do your own and as I have stated, do these modifications at your own risk! **Any time you tamper with systems on the car that will change the temperatures of the exhaust gases, you are taking risks.** EGTs that are too high will cause severe engine damage. I have not damaged my car with EGTs that have never gone past 1450 F, but that is my car with my tuning. Yours may be different, plus to know for sure, you would need a wide band oxygen sensor, so be careful! By the way, you can get the stuff to make a wide band oxygen sensor yourself or a complete one at http://www.techedge.com.au/vehicle/wbo2/default.htm.
the lower section of the PVC pipes, the turbo to intercooler section which is the hottest, that after about a years worth of use and regular hard driving (I have a VERY heavy foot!) that the PVC has not deformed or melted in any way. If there is a weak spot in the system, I guess that would have to be it, but I have not experienced any damage or downtime at all in the 2.5 years I have been running this setup.
PARTS YOU WILL NEED!!!!
http://www.jblmk3.com/05240110.jpg
5 foot straight section of 2" Schedule 40 PVC Electrical Conduit
B. (3) 2" Schedule 40 Electrical 45 deg. standard radius**
C. (1) 2" Electrical PVC Coupling
D. (1) 2" Schedule 40 PVC 'Y' 1-1/2" into 2"*
E. High heat spray paint
F. 1' section of straight 1" Schedule 40 PVC*
G. (1) 1" Schedule 40 PVC coupling*
H. Short section of 2" inside diameter exhaust tubing or just a 2" ID exhaust tubing coupling
I. Oatly Purple Primer cleaner for CPVC or PVC
J. Oatly All Purpose Cement for PVC, ABS, CPVC
*You only need these parts if you are replacing the 3000 pipe.
**You only need two of these if you are not replacing the 3000 pipe.
K. You will also need these stock rubber pieces to make the connections.
http://www.jblmk3.com/16050f20.jpg
http://www.jblmk3.com/index.htm
CHECK IT OUT IS ALL IN STP BY STEP!!!!!
