I would like to understand what had caused rebuilds to fail. If you respond "Failed - reason known or reason suspected", please say what failed and why, and be as specific as possible. Also, please indicate after how many miles after the rebuild was complete. Who did the block/head work?
If rod knock, then why? Generic bearing tolerances instead of Toyota tolerances, insufficient cleaning, etc? Had a BHG?, then why - MHG/composite with what amount of machine work and/or boost? Improper break-in? Leaky valves? - Didn't replace guides or even seals?
The main thing is, I would like to know what went wrong - the easy. Then I'd like to know why, which isn't always so easy, but lets here what you at least think went wrong.
If your build failed, be honest . Understanding what typically goes wrong will help everybody know where to spend the most time and money on builds.
Thanks,
-Kurt
EDIT: Damn - should have allowed multiple choices for anybody who built/failed/rebuilt. Mods????
Thanks,
-Kurt
