i tested the ohms and it seems to be correct but i'm getting a check engine light and it won't rev past 2k rpms. i have a blow off valve and a boost controller but i turned it down to 6 psi like stock (automatic) my AFM was broken(reading no ohms) but i soldered it and i thoiught that would fix it. how long do i have to take my ecu fuse out to reset my computer? and i was thinking of buying a new AFM on this site but am not sure if that is what it is yet. i do not have a code reader and can't find one. does a fuel cut at 2000 rpms sounds right for a bad AFM?
