wooow, talkin bout immaturity.
I'll be the 1st to say it, it doesn't matter what you've done. it only matters what you're doing....
Turbo Habanero;1466469 said:I would think about getting a D.P that gets rid of a elbow all together (Some day if you have the money)
Good luck fixing your problem. :icon_bigg
chefma70;1466467 said:look jerk.i swear im not trying to show off but since you want to try me.
heres my resume.
I stripped apart a corvette motor and rebuilt it ..(i was 15y.o)...running strong.
I built my 7m from the block up the block dident have a single piece on when i stripped it....running perfect except for the fuel cut.
rack and pinion
master brake cylinder
fuel pump
and every part that goes on a 7mgte
i won second place in Le Cordon bleu's future chef of america contest.
got 5 grand,a messermeister chef's knife, and a chef jacket and 150 bucks for culinary books.
my uncle owns two resteraunts in new jersey one called bleu wasabi and the other i dont remember. he owns two houses one costs 4 million in the nj hills.the second ,his main house costs 2 million and it has a elevator in it.
as good as you are......... im proably a better mechanic and cook than you will ever be. since you had to take the time to post you stupid ass comment im gona say whats on my mind.
your a jackass.
kikdurazz;1466476 said:Chef you need to not take the internet so seriously man. People will make comments here and there just ignore and look for the good info written. People will troll for negative responses to get under your skin, happens less on Supramania then other forums.
Word of advice I learned when I was younger:
Don't feed the monkeys.
kikdurazz;1466472 said:J-dub asked him to answer some of his questions, so he did. Then he was asking J-dub if he needed anything else answered that maybe would help the situation or if that answer wasn't sufficient.
chefma70;1466655 said:are you talking about the small boost gauge box that sits next to the masterbrake cylinder? I dont have one installed i was told that i dont need one if im using an aftermarket gauge. (was he wrong?)
If i dont have one wont that cause the ecu not to know how much boost i am running?
If i got A boost gauge sensor box and tee'd it off with the boost gauge maybe the ecu can finally read how much bost im running. am i right?:icon_razz
chefma70;1466659 said:i really truly tried to be as clear as i can be.
jdub said:Where exactly do you have the boost sensor or it's port located?
jdub said:You didn't answer my question concerning placement of the boost sensor/port.
jdub said:Thing is he didn't answer my question (boost sensor location)...the pulling teeth gets old fast.
jdub;1459925 said:Fuel cut is determined by one thing and one thing only - the volume of air sensed by the AFM. That volume is affected by air density - a colder OAT will cause it to occur earlier. If you have a leak in any of your IC piping, the volume passing the AFM will be more than the motor is using. Thus you will hit fuel cut early.
Vac reading guide:
http://www.cygnusx1.net/supra/TechTips/vacuum_gauge_readings.aspx
jetjock;1466834 said:While that may be good advice the point is unless he puts more effort into his posts he's unlikely to get decent help. Ironically, you're in the same boat. Must be that Florida thing again...
jdub;1466966 said:Ummm...what/where did you hook up the aftermarket boost gauge to? Specifics are important...at what part of the IC piping/manifold you are seeing 10 psi makes a huge difference.
