Aftermarket Steering wheel Question
jdmk3_87t
Take it!
Apr 29, 2005
472
SoCaL
The easiest way to do this is to just create a separate button for the horn on the steering column. It's way too complicated to figure out how to make the horn work when you're using an aftermarket steering wheel, especially the MOMO from the JZA70. There are a few people who got the factory horn to work with an aftermarket wheel. But to save you the headache, make separate button. It literally only takes 15 minutes to do. Here's a picture of my NRG quick release hub and a red horn button.
super.secret.supra.club
1,304
San Diego, CA
its a little too late right now but, ill get some good pics in tomorrow to show you guys how i got the stock horn to work with the momo TTR wheels. Hopefully doing this will inspire someone to create a better setup for the community. i already had a one made but never got around to completing it.
ed.d.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
excelsupra;1240389 said:
Does NRG even make a hub to fit the 86-91 supras? I've been looking thru several sites and only found 93-98 supras.
They make only one hub for toyota's and it will fit the MK3
excelsupra
Cerritos, CA
oh ok awesome. well i have a personal steering wheel that id like to put on as soon as i get an alignment done. I just replaced the steering rack, but now my wheel is not straight.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
ed.d.
Did you get around to it? I want to install the TT-R wheel in my car, but I want to be able to get the horn to work. I was planning on getting a horn button and possibly a retainer ring if I need one and connecting it below the middle cover and having it work under the cover like a regular wheel.
It does however have a white plug on the back with two wires leading from it so I may be able to just attach a horn button and plug straight in. I have to check the plug out tomorrow and see if it will work with the stock plug.
