so my car is a 91 mk3 turbo auto white package
factory alarm is not wanted so i removed theft deterrent module and grounded starter wire to ground(starts fine)
now the alarm i have installed is a Viper VH350 alarm with keyless entry
so far i have ran constant 12v, ignition wire, ground, starter kill relay
the issue im having is with the door switch trigger wire
alarm has 2 different wires for this...1 for if power is supplied with door open and other for if ground is supplied with door open
from what i have read and understood door switch should show ground or 1.0v with door open but im getting 12v with door open
also i need to make sure im reading the right switch...is the door switch the 1 with black rubber piece covering it or is it the lever that pivots on door and seat belt assembly?
i have found these following forums with little info on door switches
http://www.supraforums.com/forum/showthread.php?172172-MK3-car-alarm-install-DIY
this is a link to car alarm connections
http://www.modifiedlife.com/1991-toyota-supra-car-alarm-installation-guide/
better link with a pdf file of install
http://www.supramania.com/forums/showthread.php?101-Aftermarket-Alarm-installation
2nd page down he shows the door trigger wire at fuse box
1N-7 red with white stripe wire...now i measured voltage and it showed 12 volts with door switch depressed and not depressed
shouldnt my voltage change?
to sum it up im trying to figure out whats causing my door switch harness to constantly show 12v
also my dome light doesnt work with the doors opening anymore...i figured its the common bad connection in dome housing...but pressing map lights make the lights come on
thanks for any input
