aftermarket cams in a 1jzgte
scottiedawg66
Bay Area Ca
I had to order a butt load of shims when I did my cams, it was 7 years ago so I do not remember what I used. If I was you I would call up Kurt at Elmhurst Toyota and order through him. They have awesome prices and he is a 1jz / 2jz expert.
zac101191
57
wheelig
Took the head off yesterday and rounded the top of a head bolt but I was able to drill it. After I got the head off I decided to try out the toyo tool, and man it is badass. That tool makes life so easy with the valve train.
seoul4korea
620
San Diego, CA
www.supraforums.com
I got lucky and didn't have to change one shim
zac101191
57
wheelig
I ended up putting 2jz cams in it. I got a good deal on a set so I couldnt say no. Only waiting for a couple more things then I can put it back in Im so excited!!!!
JPsToyota
231
East-Central, FL
The Brian Crower's are notorious for having the 'timing' pin incorrect on them, even though they tell you just to install them straight up and run them. Tried that, I actually run one of mine a tooth back on the adjustable cam gear now after taking the valve covers back off and degreeing them correctly.
