jdub;1242305 said:Look at this for the coolant hose routing:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=CO&P=2
Hose starts at the hard line that goes around the block, drivers side rear of the motor--->TB--->ISCV--->fitting on the bottom if the lower intake manifold, under the #2 runner.
You likely have a vac leak...check this:
Block off the hose that runs from the accordion hose to the ISCV so no air can pass while the car is running. If it dies, you don't have a leak...if it keeps running, you do![]()
Well that little hose by the ISC, i pinched it while the car was on. The car didn't die it was idle really really low!! I guess i have a vac.:nono: leak i can't think of where that might be. My boost gauge reads Vac 20psi at idle good or bad??
Behind the engine where the EGR goes there's 1 hole back there. I stuck my finger in there and it was pretty deep, im more then sure this is where the block off plate goes for the EGR right??? if so i think that's the vac. leak
