After 3 months in the bodyshop, car is back!
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Most long rubber seals require some 'massaging' to get to fit. It's that it stretches so readily over its entire length, that it appears to be too long, when infact it's just stretched a few percent. A bit of patience and fiddling usually yields the required result.
SupraTrey
Boost-A-Holic
Dec 16, 2007
Seattle WA
Beautiful!!!!! That is the same color I used on my car. With the Blue Pearl it clouds it a bit but anyway.... BEAUTIFUL!!!!!!!!!!!!!!!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
tekdeus;1112503 said:
Hard wire the CPS by cutting off the plug and soldering the wires.
Why the hell would you do that when GM weather proof connectors are easy to come by and dirt cheap. If the CPS doesn't have a pigtail add one and put new connectors on both the CPS and harness.
The car looks GREAT.
You could also get the pigtails for the coilpacks and fix it properly (or replace the CPS and harness like I did since my CPS and harness was screwed anyway)
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
As the owner of a white package 90 with the original paint and chips from a local f2 twister I'd say that looks excellent and was more then likely worth the hassle, MK3's look good in white!!!!!
Nick Stonawski
403
Manhattan Beach
glad to see the lip worked out afterall. ;)
from reading ur post, u confirmed with me the bodyshop isnt very compitent. I'd look around for another next time cause i think they were taking u for a ride on that lip deal too. Any body shop should have figured out immidiatly the lip was upside down rather than try and charge u $200 more to "fix it". Bunch of idiots!
edit: realized ur a woman too just now, and makes sence why they tried convincing u to cough up extra dough. rephrase my last comment, they're a "Bunch of Assholes". next time take a guy down there so they wont take advantage of u like that. :nono:
tsuper92
supra addict
Apr 7, 2005
1,376
mass
car look's great in the pic's.how about pic of car with owner,not many female's rock a supra:)
ZoomZoomZoom
On the road again..
Dec 9, 2007
443
KY
suprahero;1112094 said:
Very clean looking car. Can you get a closeup of the pinstriping?
Will get a close-up pic up this weekend. Would like to hear opinions on it!
Zer0DeGreeZ;1112261 said:
Just curious gentlemen. But what have you fellas that have had these paint jobs paid? I'm about to start on my car through a local shop and they say with stripping everything and all new trim and mouldings, and re-strengthening the frame, i'm looking at about 8k-10k depending. Now I don't mind paying it given thats normal average for what i'm doing. Now mind you they are removing all panels they can, removing enging/interior and respraying the frame black, and the car body seperatly.
I paid half of what you were quoted, I pulled all the lights, molding, spoiler, and door panels off myself. I had the door jams painted, alot of rust repaired around the windshield. I had replaced the hatch, the spoiler holes didn't line up, so the old ones had to be filled and new ones drilled. Also had to pay to install a new starter (ugh!) and had the new lip painted and installed.
Poodles;1112797 said:
The seals are made to the right length, don't stretch em. Gotta work from the ends to the center.
They are NOT to be glued in place! Previous owner made the same mistake on my car, they fight into the channels and have adhesive strips in some small places.
It's all covered in the TSRM if you look... Also, I sprayed mine with silicone spray the first time I put the targa on so it slipped in right. It's a tight fit until the seals break in a bit (think of an insole of a shoe).
I did check SM, and I did line up the ends with the screw holes, started from the ends and worked my way to the center. There was alot of extra material at the front of the targa, and I trimmed it back to fit very snug to the seal on the car. I was stuck in traffic during a downpour the other day. Not a pretty sight. I had to go home to change clothes and change cars :3d_frown: So, since I'll be overhauling those seals, can I PM you with questions? I'm confused on some of the steps.
Can't order a new wiring harness, no longer available. I guess I'll be learning to wire it myself because I would like to get the oil pressure gauge and the cruise control working again.
Actually, I liked the shop real well. Tim was very respectful of my knowledge of the car, and worked with me to get the look I wanted. It was my fault the lip was upside down because that looks more like stock than the other way. I actually prefer the stock look myself. Nevertheless, he offered to make it fit the way I wanted it to. He really didn't want to tear into it. I was on my own with this project because the only guy around here that knows more about Sups than me works second shift and couldn't be there every time something came up.
Will get that pic up this weekend too. Have to update my .sig!
THANKS FOR YOUR HELP AND COMMENTS GUYS!!
Sure, you can PM me, but it's tough to explain what to do with the seals.
The TSRM is your best bet as it has some pretty decent pictures. The first time you put the targa on it's going to be very tight, that's why i recommend the silicone spray to lubricate the seals so they don't bind on eachother.
Is your car an auto? If it's a manual car the harness is still available (most dealers will lie, hell even the two sponsors on supraforums said they where discontinued, but they just have be ordered from Japan).
ZoomZoomZoom
On the road again..
Dec 9, 2007
443
KY
I have an automatic. Jeff at Champ told me they were discontinued. I figured that would be my most reliable source.
Here are close-up pics of the pinstriping added to the body molding. If you look closely, you will see a tiny black stripe right on the very top of all the molding:
Should I leave the pinstripe on, or take it off?
No IJ, I haven't forgot YOUR pictures...
SWD Fredester 3
675
baltimore maryland
AS said, your car looks great, well worth the wait. The pin stripe is debatable, appears not to be too noticeable, if anything I might have picked
up the interior color in the pinstripe. Main thing is it certainly doesn't
detract from the overall clean statement that your car makes.
Thanks for putting such a BIG smile on IJ's face, with all he does for every
one on here he deserves some special recognition .
