The maft-pro uses its IAT sensor in combination with it's MAP sensor and enters the readings into the equation that makes speed-density possible, then out puts the results for something the ecu can read, which for the toyota supra mk3 ecu, is in hertz.
The brown wire from the maft-pro is the temperature output wire that ecu looks for.
Because the maft pro is slower to boot up than the ecu despite hooking it up to either ACC or ON power leads from the Key Ignition switch, it becomes necessary to use the resistor in the old afm wires to hold over the ecu until the maft-pro fully boots up.
Remember the 'Vol Setting 1' menu and you entered 2.4, thats one of the values the ecu looks for but doesn't see soon enough at start up.
So the brown wire supplies the ecu with a temp signal, the resistors makes codes 24 and 32 from startup go away, and the ecu throws codes making it hard to drive even if it does self resolve temp to 65.
Keep firing away with questions, this is the best way to learn
