I'm a little confused about how my fuel pressure regulator is supposed to be setup. I have a SX model 15402 http://www.sx-performance.com/15402.PDF
It came with my car and the vac line appears to be connected to the "fuel pressure up" VSV under the intake manifold. What is the purpose of this VSV, and would I be better off having my AFPR connected directly to vacuum?
My fuel pressure is set high (by the previous owner) at 50psi at idle. However, it does not change when I unplug it's vac line, and it does not change under boost either (I have an in-car fuel pressure gauge).
How much extra fuel pressure SHOULD I be seeing with each psi of boost? This SX AFPR has a pressure regulation slope of 3 psi/gal of flow rate change.
I pulled 20hg of vac on the AFPR with my vacuum pump and the pressure dropped to 45. I get the impression that the VSV it is connected to is not working, and I'd be better off with a direct vac line connection?
After hitting fuel cut for the first time the other day when it was cold out and I had my test pipe installed, I think I need to look at adding fuel with the AFPR and pulling fuel with my SAFC. Especially now that I'm looking at getting a larger turbo.
Mods are Lex AFM, 550's, dual walbro pumps, SAFC, LC-1 wideband.
