afpr needed?
supraian
66
san diego
i'm gonna be running around 14-16 psi my current fuel system is lex afm, 550's, 255 walbro pump and 12v mod. will the stock fpr be able to hold the pressure from the walbro or should i get an aftermarket afpr?
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
What MKIIIman was talking about is.. If you drill out the J-tube and you have a problem with the stock FPR you run a risk of low fuel pressure. That little pinhole in the J-Tube acts as a failsafe to provide higher fuel pressure.
Hope that helps..
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
The AFPR isn't NEEDED, but it sure would be something to good to have so you can lower you fuel pressure when you discover you're running pig rich and need to do something about it ;).
Bishop92t
773
USA
www.ma70.com
AFPR, drilled or remove j-tube, and 12v mod are not needed for your mod level. However the first 2 are definitely good insurance.
