AFPR Install on 2JZ fuel rail
crazysupra2JZ
740
Georgia
i've been searching but i can't find what i need. what do you do with the fuel rail return port? do you have to tap the hole or do you attach something on the existing FPR? i just bought an Aeromotive FPR and i have a nifty little gauge and now i don't know what to do. i know how to hook it up, but HOW?
thanks guys
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
you remove the old fpr get the adapter metric to AN then run hopefully a -6AN to the regulator you dont need the larger one unless you have a lot of power on your 2jz setup.
What i mean by this is there is 2 diffrent types of afprs.
run the vacume line that went to the old fpr to the afpr then plug your return line into the bottom hole on the afpr and adjust it using a non-liquid type because aeromotive haves an artical on how the liquid ones are not as acurate but it have been said that the non liquids are more likely to break do to shock.
crazysupra2JZ
740
Georgia
well, i ordered an adapter from Sard and should be here next week. i was thinking abou your idea hottscennessey but i was worried about getting a good seal that way. AN fittings seal on the beveled surfaces and i can't make that inside the fuel rail
