From what I remember you can tie the Stock signal into the UEGO. Isn't there something you have to change on the back of the gauge? Also, what wire do I use from the stock harness?
x87SUPRA87x;971035 said:From what I remember you can tie the Stock signal into the UEGO. Isn't there something you have to change on the back of the gauge? Also, what wire do I use from the stock harness?
im talking about using the wideband to also run the ECU signal to eliminate the OE oneJohn Reed;971073 said:Some of the AEM UEGO (the non gauge ones) have a 0-1V output to emulate the stock O2 sensor which can be hooked to the stock ECU (if needed). Is that what you were referring to?
There would be no reason at all to run the stock sensor into the UEGO.
x87SUPRA87x;971193 said:im talking about using the wideband to also run the ECU signal to eliminate the OE one
yes you can do it with either one....mischief7m;971498 said:is this do-able with a 1jz also? or is it 7m specific?
