I got my AEM V2 up and running pretty well and am starting to do some light road tuning. It idles, run and drives pretty well but medium load (~ -6 psig to 0 psig) at low rpms (1500-3000) it stumbles and actually kicks back just a little bit. Higher RPMs are a lot better but it also feels like it doesn't want to build boost. I had this setup running on the stock ECU/Maft Pro pretty well (IS300 coils, 660cc injectors).
My tach is also reading different than Tuner Pro. It is a couple hundred RPM off at idle (reads faster) and progressively gets worse with RPM to about 500 RPM difference at 4000 RPM. It also is a little erratic at idle, "bouncing" just a little bit like the signal is off. Here is what I have verified:
Cliff notes:
Symptoms:
* Stumbles at medium load (~ -6 psig to 0 psig) at low rpms (1500-3000)
* Tach is a little erratic at idle and differs than what Tuner Pro sees, with the difference increasing as the RPMs rise
* I rack up a few timing errors during driving (about 13 on my last 1/2 hour drive with the laptop hooked up...not much but I need to check my wiring)
What I've checked:
* Base timing is set to 10 degrees via the ignition timing sync wizard
* AFRs are within 5% of my target AFRs during these load conditions
* Logs look fine...timing matches what's on the ignition map and all injectors are firing at the same pulsewidth that corresponds to the fuel map
Any ideas? I wanted to give it a light road tune before spending $$$ on a dyno tune so they don't have to troubleshoot this.
Cliff notes:
Symptoms:
What I've checked:
