I am in on the timing being off. I am fighting issues with timing on my v1 right now. It wont run past 6000rpm just drops all power under full throtlle, but under partial throttle i can run it up to redline. Redline is set at 7000. Been fighting it for a few weeks now. The tuner I keep having play with it keeps fucking the map up so I have one of the best tuners in the nation looking at it right now. I also have a dead spot around the 3000 mark when its coming into boost.
I do think my problems, and possibly yours are timing issues. Make sure mechanical and cps timing is spot on, then remove a few degrees of timing from the map is what I am thinking. I don't personally play with timing as I have no idea what im doing with it, so I leave that up to the tuners.
If I get my problems worked out tonight Ill try to remember to post up my results and see if i can let you know what the problem was.
