no wonder it's better then.
i don't want to mess with my load fuel or timing yet, until i understand more about it, so keep that in mind with my questions. i'd rather get the idle better, right now it's very rich.
so looking through my map, found a few things, keep in mind i dont have idle air control at the moment (FFIM and BBK 60mm throttle body):
ENGINE START:
fuel pump prime = 0 ...... no trouble cranking/starting, but i always key on for a few seconds before cranking. leave it?
IDLE:
hi idle car speed = 410 KPH .............. this seems wrong to me, seems like i should be in high idle at anything above say 60 KPH?
idle fb above rpm = 300 ............... my crank exit is 400 rpm, should this match be the same? i have no trouble with cranking/starting, it starts right away every time.
idle fb below rpm = 2000 ............. seems high, but the car doesn't stall when letting off the throttle at speed, so i figure leave this as is
O2 FEEDBACK:
O2 FB coolant min = 60 ......... so this shouldn't be effecting my cold start anyways.
O2 FB Accel Clear, DFCO Clear, and Over Clear = unchecked ............ my DFCO is set up and works nicely, so any problems with checking these three?
DFCO
everything here seems to work fine, but Fuel Off Coolant Min = 0, so i figure i should change this to 60 *C to match my other settings
FUEL:
Knock Control = unchecked.... not sure on this, opinions?
Warmup Enrichment: Currently going from +30% at 0*C, tapering pretty evenly down to 0% at 70*C ...... seem ok?
Injector Trim: currently #1, #5, and #6 are seeing +2-4% at 3200rpm. shouldn't these all be set the same? I couldn't find anything about it in the manual, but i might be looking in the wrong place
