here is how to change microbit sec. it is in the first reply on this boost fuel comp thread that every aem owner should read repeatedly till it is understood.
http://forum.aempower.com/forum/index.php/topic,11494.0.html
first reply is as follows:
"Bummer - can't attach files here or I'd add examples to this post. AEM can ya' help me out here?
First this setting can only be found if you look at the Options, Full List. It's called MicroSec/bit.
Okay - so what's MicroSecBit? Pull up the Fuel Map, Right Click, View RAW. The numbers in those cells can be between 0-255. Look at peak torque at peak load - are you close to 255? Now look at idle - are you close to 0? You can actually have 255 in one of those cells and NOT have full fueling! You can also have very small numbers in the idle area and find that making changes as small as one increment will swing A/F by a LARGE amount. Neither of these situations is one that you want. LEts say the idle range has a number of 10 in it - moving to 11 you swing fueling by 1/10th - that's alot! My idle numbers are over 100 - now THAT is granularity. MicroSecBit or MSecBit is what defines the value of "1" in the fuel table. You CAN modify it!
So, before yuo go playing with that number realize it will have BIG impacts on your fueling. Here's how you change it "safely". Open the fuel map, right click, View Duty Cycle. Highlight the ENTIRE map, right click, Copy to clipboard. Now modify MSecBit up or down and then Paste the fuel mapping back while still looking at Duty Cycle. Right Click, View RAW. Any numbers over 255? IF yes then MSecBit is too small, switch back to Duty Cycle view, make it bigger, Paste the previously saved table, and check the RAW view again until the numbers are big but not huge. Note that if you use Boost Comp as explained above you'll also gain granularity. Doen CORRECTLY fueling shouldn't change much and the car shouldn't need too much retuning when you now upload this mapping to the ECU."
very useful
