Advantages of running MAS in "Blow Through"?
chriso
Supranian
Bay Area, CA
What are the advantages of running a GM MAS in "Blow Through" mode vs. using a stock or Lex AFM? Should I stick with my Lex or go the GM route?
I am ready to purchase my MAFT-Pro and don't quite understand the full capabilities of the unit especially running the "blow through" style. And, yes, I've read through all 80+ pages of the post in here.
90T04
Tucson, AZ
www.azsupras.com
You can only run speed density with the MAFT Pro. The regular MAFT unit only lets you run a GM MAF (mass air flow sensor). The MAFT takes the signal from a MAF sensor and translates it to a signal usable by the Toyota ECU.
Speed density based air measurment utilizes a MAP sensor (or Manifold Absolute Pressure) sensor to determine the amount of air coming into the engine. The MAFT PRO translates the signal from the MAP sensor and provides it to the Toyota ECU in a form it can recognise.
But to answer your question, the advantage for me running in blow through mode was the fact that I didnt have to have any pre - turbo restriction. I just used a 4" intake pipe to a large filter, and installed my GM MAF in the IC pipes before the TB.
Some people have said that the MAF is not supposed to have pressurized air flow, but honestly it works perfectly in blow through mode. My car ran better with the MAF in blow through than it ever did with a Lexus AFM.
Hope this helps.
Ryan
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
:withstupi
The perks of running GM MAF in blow through seemed so petty when i first considered it, it was only after i installed it when i realized what a great modification it really is. I love it, and the only reason i wouldn't switch to MAFT Pro is because this works so well for me, it wouldn't be worth switching.
chriso
Supranian
Bay Area, CA
Hope this helps.
Ryan
Yes, it helps a lot for me to understand. Thank You. Now I only have a 60-1 Trim CT-26, so would it be advantageous for me to run this method?
hottscennessey said:
:withstupi
So you wouldn't run MAFT-Pro???
Untouchable7mgte
back in the game!
Wilkes-Barre,PA
amen love my MAFT. Blew numerous IC pipes and the car rans like nothing happened. Just wish i had a wideband to tune it a little more. that Vf signal thing sucked
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i couldn't see any reason not to run speed denisty,
it's the way i set mine up.
i can have no filter pipe, or run what ever cobination i want off the turbo,
i have a air temp sensor about 10 inches before the tb, and have the map sensor posted on the back on the manifold by the fire wall.
speed denisty is a calculation done by the pro, which figures rpm, air pressure, air temp,pump size (3L in our case) tps, and figures out how much air is going through the motor at 100 percent efficcy, know this will give you how much mass the air has, and how much fuel should be added.
Cya
628
Columbia, S.C>
another point the should be said is that to run blow through mode you need your MAF to be 6-8" from the TB, the same goes for the MAF to the BOV.
