Adjusting the power steering pump for lower pressure, has anyone done it?
NashMan;1787742 said:
playing with caster is stuiped and makes the car handle funny and messed up
If done correctly it achieves a desired result, seriously Nash don't call things stupid just because it's not how you would do it....
Increasing Castor makes it much more stable at high speeds and will make the self centering firmer which is what the OP is trying to achieve.
destrux
1,183
10
PA
I have my toe set to about .05 degrees toe-in, and caster is set to 90' specs, but I will play with them a bit.
I drove the car all over the place yesterday and it worked great so far, the rack seems to be happy with this pressure. I can steer as fast as I want and it feels the same, no weird stuff. I can't find anything about a pressure relief valve in the rack, I think those are only used in older recirculating ball type steering gear boxes.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
I don't care this is my obsvation I did not like it when I was having fun at auto x or windy roads, funny part is I ended up with 2 adjustments
stock grade that comp sates for road crown, and = for back in the track day when I installed my 2 way lsd to keep my SAI in track
