Recommended supporting mods needed to support Boss Series Turbo's.
Bold italic underlined items can be optional but are highly recommended.
High flow intake (Apex-i, Blitz, K&N, SS Intake Kit)
3" Mandrel bent cat back exhaust (RS-R, Blitz, Tanabe, etc.)
3" Test pipe (check state regulations) or cat (Random Tech, Vibrant, etc.)
3" Down Pipe and Elbow (RT, LIPP, Cooleeze, Tanabe)
Walbro 255 fuel pump or larger
Fuel pressure regulator (Aeromotive, SS General Install)
550cc or larger injectors (RC, PT, Venom)
LIPP or Lexus AFM upgrade with Apex-i Super AFC-2 or other similar engine management (MAFT-Pro / MAF Translator with GM Blow Through AFM, AEM-EMS, Greddy e-manage)
Wide Band o2 Sensor kit to monitor EXACT air & fuel mixture from exhaust After but closest to the turbo usually side by side with the stock o2 sensor (the stock o2 sensor system will need to remain installed and DO NOT TAP INTO THE STOCK SYSTEM the main computer still needs this, the wideband has its own controller) (NGK AFX, AEM UEGO, Innovate Motorsports)
Full intercooler hard pipe kit 2.5" or larger
Intercooler
Blow off valve (single or dual Bosch option will not be sufficient, should be on of the major brands)
This may help with what you may need
Greg
Lipp/SS
