NDBoost said:wait so what exactly is the significance of disabling the neutral start switch and thrust washers?
so you can start your car without puttin in the clutch...
i know its purpose, but whats the point of disabling the neutral start switch to save your thrust washers? Wouldnt you want to NOT disable that... i mean, starting the car in gear cant be good on those thrust washers...can it7M-GTE said:so you can start your car without puttin in the clutch...
NDBoost said:i know its purpose, but whats the point of disabling the neutral start switch to save your thrust washers? Wouldnt you want to NOT disable that... i mean, starting the car in gear cant be good on those thrust washers...can it![]()
yes i could see the point of that, which is one of the reasons why im not using it in my 5spd swap process but i dont get the point of disabling the neutral start switch to save your thrust washers from being destroyed?7M-GTE said:I'm sure it's not good at all for your car to start it in gear... someone in another thread was talking about disabling it so they could put in a remote start...
NDBoost said:yes i could see the point of that, which is one of the reasons why im not using it in my 5spd swap process but i dont get the point of disabling the neutral start switch to save your thrust washers from being destroyed?
IHI-RHC7 said:Hmm, You guys are paying too much, I got my bronze disk and act pp for $100..:evil2:
