Good update here. Digital mutli-meters for the win.
Alright, the old multi-meter was bad. The new digital one from Lowes said that it checked out on all connections. Good.
Next up was the coil pack. I couldn't get the connector off, so I had to punch through the wires (I know, I know :3d_frown
. The resistance jumped from .2 to .3, which is in range, but it also spiked to .4, which is not in range. I wasn't sure if that was just a bad connection because I had to jump the wires, or the coil is going out.
I went back and adjusted the TPS with the new meter. Haven't checked out the CSI again, or the water temp sensor, but those are next. I should also be able to check the VF signal much easier now.
The check engine line didn't pop up when I took it out for a drive, so that's a good thing. Initially, I had forgotten to plug the TPS in :nono:, but when I plugged it back in the idle dropped from 1200 down to 700 and got a little bit rougher. The acceleration characteristics changed, but I got a better picture of what it's doing. Under 2900, it misfires, and lags, but isn't terrible. Between 2900 and 3400 it sputters, and runs like utter shit. Hit 3500 and all is cured, the car runs jumps (literally) to life and pulls fine. Sometimes these numbers vary by a couple hundred rpms.
The local mechanic never got with us, so I'm going to have to check and see if the local o riley's or autzones rent out fuel pressure and vacuum kits for reading the corresponding pressures. If not, it'll take me a bit longer as I'll just have to cough up the money for the kits, and money is in rather short supply right now.
So what do you guys think? My problem does sound similar to what the MR2 owner in A-model's post described. But mostly the part about how the car will get worse as it warms up, and how the motor clears up in the high rpms.
According to the TSRM, the igniter is the last thing on the list to replace in the ignition department (coil comes first, we've already replaced the ECU). It really doesn't give any way to check the resistance, so I'm kind of stuck for now until I know for sure the coil pack and distributor check out 100 percent. And ... I still haven't went out and checked each ground either, though I have the TSRM page on it bookmarked. There's only so much time in a day, and there's quite a bit of things on this car to check to solve a misfire, heh.
I'm not really sure it could be a fuel pump issue, except for the relay. I would think that if it was the pump itself, or a clogged filter, or dirty injectors, the motor would not liven up at the top end once it hits the powerband. It would be a crappy run all the way through. I am thinking the relay may be suspect though, because if it isn't switching from low to high properly then that could cause problems at the low end.
A headgasket, well, again, I don't know for sure. I'm thinking that if it was a crack, then it would only get worse as the motor cooled because the gasket expands as it heats up, possibly sealing the crack. But headgaskets are a complicated issue that I don't fully understand.
