Hey guys, I have a 1990 supra turbo and the ac isn't working. The car is at the shop but there are some issues fixing it. First, we are pretty sure the climate control unit is toast. it tested bad, and I put it in my 87 turbo and it did not work. To clarify, there is no difference between 87-92 with the climate control correct? what about NA and turbo? If there is not a difference then my 87 good climate control should have worked in the 90, but it didn't! This leaves me to think that the 90 has a bad climate control, and another problem somewhere. Knowing this information will help, because my mechanic doesn't know for sure that the climate control are the same for these different years, but I remember reading it on here when searching, just need verification.
thanks,
John
thanks,
John
