It'll be fine. More rugged in the sense it's less likely to be damaged by impacts. On the other hand it has lots of vacuum brazed joints, something flat channel designs don't. Looks well made though. American
CyFi6;1290332 said:My recommendation would be to stay away from R134A with all stock components. I did my AC system recently and used R134A as well and im not pleased with the results. Im not coming here to tell you R134A wont work well, but just sharing my experience, and for whatever reason, it didn't. I suspect the condenser, it is very small and too inefficient to run R134A, i think.
I did all my conversions properly. I removed every component of the AC system from the car and flushed all of them thoroughly. I put all new seals, new receiver dryer, new TXV and new oil in the system (used ester) and put the right amount of it based on the TSRM, and compensated for the change from R12 to R134A. I evacuated it and charged it with the proper fill of 134a and went on my way.
Ive found the AC works great in average weather, but as soon as it starts to get hot out the system struggles to blow cold air around town. As soon as i get on the freeway and drive a steady 65MPH i start seeing a decrease in vent temps and it actually gets as cold as it should. Take note my car is an NA with a Turbo 10 blade fan, brand new OEM Turbo fan clutch, good fan shroud, good engine undercover etc. All systems are how they should be, and i still see high vent temps around town in hot weather.
My theory is that with the amount of airflow our fans can provide at lower speeds, its just not enough for what our condenser needs (with R134A). Whether or not this is correct, im just stating my opinion (just something to think about).
I also recommend you take your parts to a professional AC shop to have them flushed. Many off the shelf AC flush things are no good, they have way too much oil, don't evaporate properly and are designed to be safe for your system when some dumbass comes along and doesn't get it all out and puts his system back together. Pro's have specialty tools that blast flushing solvents at high pressures through all your components (don't forget you CANNOT flush an evaporator with the TXV installed, this means if the evaporator is in your car it needs to come out.) They also have the means to properly and 100% dry all your components. Compressed air through a standard blow nozzle supposedly doesn't flow nearly enough air, and they recommend you dump a lot of air all at once to get the amount of flow you want. I found it a PITA to flush out my condenser without any good tools.
I also highly recommend you replace the TXV with a new OEM!! one. I bought an aftermarket TXV and its orientation was different, the temp sensing bulb was merely a coil at the end (not a bulb like stock) and the diaphragm was facing a different direction than stock, and my lines had to be slightly bent to get it to fit. I was told this was normal, but i wouldn't do it again.
Anyways sorry my post is so long i just want to inform you of my experience. I would go with R12, its a better refrigerant and its what our systems are DESIGNED to work with. Its expensive but its not outrageous. Go pay 20 bucks, get your 609 license and prance around with your r12 all day long.
grimreaper;1291204 said:Might explain his ice cold air although we'll see how the stocker handles the tx heat this summer. The cost is more then i can afford to replace with a parallel flow condenser and re do the lines.
CyFi6;1290332 said:compensated for the change from R12 to R134A. I evacuated it and charged it with the proper fill of 134a and went on my way.
