Originally I was fixing both. AC still does not work, heat does. I had to replace the heater valve switch with a known working one. This solved the heat problem.
I am now working on the AC.
I then went on to ask about the diagrams listed in one of my recent posts, where it talks about the AC Amplifier. Due to condition A in the diagram (open circuit) it says that the heater valve will remain always open, even if the temps are turned down in cabin. (which it is) I was wondering if the AC amplifier being a likely cause of this, or if I should look elsewhere.
I also asked (which grim jack gave a good hint) , if the auxiliary fans (two small ones on drivers side) were related to the AC and if they wouldn't be turning on because of a related issue.
I am now trying to diagnose the problem with the AC.
I think it may be either the amplifier or the pressure switches. From the diagram in my second to last post, I am beginning to believe the amplifier has an open circuit. I also am unsure if the diagram is referring to the amplifier internals (open circuit situation) or to the entire AC circuit. However at the end of the diagram it says to replace the AC amplifier.
I am looking for likely sources, or opinions on my thoughts so far. Thanks
