about to buy a Mk 4 with some issue
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
driftboi said:
Hi guys I was looking at a Supra that was a non turbo then was swap with a turbo 2JZ with a JDM harness. The problem is the ABS and Air bag light stays on due to JDM harness and the RPM Gauge doesn't work due to that problem so the owner installed a shift light. Can this be fix?
Yeah, buy a usdm harness. Should cost you maybe $950 at Toyota. Problem solved. A working running MKIV for less than 10k! :naughty:
Edit: That works too!
SirLoki said:
im guessing the guy never changed the tach to a turbo tach..... thats all you need
