Rennat;978153 said:just make sure they can hit an RA Spec of at least 50
MHG or not... its better to have a smooth surface.
If they have NO idea what an RA spec is... hang up or walk away...
IJ.;978236 said:Well actually no.....
Composite gaskets work better with a coarser surface finish.
As the head and block move in use the "teeth" from the cutter marks bite into the gasket giving a better seal.
Can't do this with a MHG as it's non deformable, composites have .6mm of crush.
