A340 FTL
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
No, because I am using name brand proven pieces for the transmission. I am just not paying someone the labor to install them :) That's 90% the cost of a built transmission. It's alot of hours of labor thats very easy, but just alot of it, as long as you are good at following directions. If i fuck it up, I'll give it to my friend to do it.
It's no different then installing a flywheel or clutch in a 5spd car.. just a little more involved. I've seen these things rebuilt in a few hours. It's my spare tranny on a shop table, it shouldn't be bad.
csnow
Matthew 6:33
Palm Bay, FL
Good luck with that. Building a high performance auto with a "how-to" guide is not going to be as easy as you think. Any yes, it is different than installing a flywheel and clutch. But good luck with the build. Props for trying!
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
thats what im getting at
you're using cheaper parts to make the samething as BL's
holsset works the same as any other turbo
and 349 at 12 psi on a 2.5 is damn good
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
I won't be adding extra clutches, just replacing the stocks with Raybestos Blue's like most places do. Like i said, nothing serious.. but it should hold 600whp for a while.
Seemingly there's an Oil feed issue to the planetry gears set that needs the case mod to prevent failure..
MV uses Brown clutches as according to Mike they have more friction area and hold better than Blues.
