I've been holding back on the boost out of fear of cracking 600hp w/o this pump installed with my 680's.
For those of you with this pump:
Are you using the existing fuel pump wiring and doing a 12v constant mod?
Or are you running a dedicated wire from the batter to a relay and a secondary on/off switch?
Plumbing:
I'll be doing a dual feed, most likely a -10 from the tank to the pump, and then a -8 to the Y adapter and -6's to the rail.
Is it okay to use the CSI port for the return?
I think that does it for my questions... Thanks!
-Brent
Plumbing:
-Brent
