Backlash2032;1961137 said:Last I checked, 10* BTDC
Sent from my HTC Droid DNA
When was the last time you checked?
IndigoMKII;1961176 said:When was the last time you checked?
Backlash2032;1961194 said:Yes, I checked the timing because of this issue.
With the stock ct it would boost fine, albeit 6 pounds and it was kind of slow. So I checked for boost leaks and found none, and the turbo was blowing oil so I replaced it with a 57 trim. Didn't fix the issue, and it seems sluggish. No turbo whistle either. I replaced the engine harness because of random MILs and terrible gas mileage, and that did fix those two issues, but its still slow and sluggish.
With good gas mileage, good compression, no boost leaks, the only thing I can think of that would do this is a bad turbo or a bad pre turbo exhaust leak. Am I correct in this thinking?
Backlash2032;1961242 said:Plug gap is at .030. And wouldn't that cause spark blow out rather than just a general lack of power?
BryanDyer;1961244 said:That's what I would think. Did you check the gasket/bolts on the exhaust side?
Backlash2032;1962546 said:So, to expound on this a little more. I believe all this turbo needs are new bearings. It is a lot tighter than my factory turbo, and comes to an abrupt halt when you give it a good spin. It also will stop spinning at idle, and even giving it a flick with the engine running will only result in maybe a revolution before it stops spinning again.
I have to say though. A 57 trim at 4 psi makes me want a 57 trim at 12 psi lol. I will probably look into putting new bearings in this turbo.
BryanDyer;1962618 said:Glad to hear you found the problem! Easy fix too.
BryanDyer;1962624 said:Are you on the appreciation page on Facebook?
7M4EVR;1960856 said:Do you still have your stock turbo? Could always try throwing that on.
7M4EVR;1962634 said:Could have saved u a week of finagling if u just did this then lol. But I do still wonder if you just put some damn boost through that 57 trim if it would open up for you. I bet u just need to blow the cobbwebs outta that thing.
Turbos are like vaginas...the more you beat on them, the looser they get. Just be careful, too loose and you have to replace them...turbos don't do kegels man.
BryanDyer;1962629 said:Join the Toyota Supra MK3 Appreciation club. Really friendly people and super quick response. One of the guys on there rebuilds 57 trims, well known for it. Can't remember off the top of my head but if you join and post status someone will know and you'd be able to get a rebuild real soon. His turbos are known to be reliable.
