a plate on the back of the head
with like 7-8 bolts? that would be the egr cooler cover.
there is the metal pipe that wraps around the block, the union bolt on top at the very back in the middle of the head, a cap, and a hose that have coolant right there tho.
gofastgeorge
944
Texas
Yup, if it's leaking from around the banjo fitting.
I have see several that leak from the hose there because the fitting is 20 years old, and the surface is corroded.
When I redid my latest engine, I just bought the whole set, fitting, banjo bolt, and seals.
90401-22004 Rear water outlet banjo bolt
90405-17005 or 90405-17006 rear water outlet
90430-22008 rear water outlet banjo gasket (2 req)
