Yup, if it's leaking from around the banjo fitting.
I have see several that leak from the hose there because the fitting is 20 years old, and the surface is corroded.
When I redid my latest engine, I just bought the whole set, fitting, banjo bolt, and seals.
90401-22004 Rear water outlet banjo bolt
90405-17005 or 90405-17006 rear water outlet
90430-22008 rear water outlet banjo gasket (2 req)
