OK. I think you are missing the point. GE and the GTE sound totally different, believe it or not. If you want to go ahead and run a straight pipe, then do it. When your ears bleed profusely, then youll probaly wish you had just taken the advice that has been given to you repeatedly. Cut your rear most muffler off, start your car, and listen. Then, work from there...
