I had typed a big thing here, but ya, my initial machine and electronics were all sourced from entirely out of photocopiers. I didn't have any previous education or machinist experience of any kind previously.
But love seeing all these machines regardless. I can drool, but I'm on a budget of nothing literally so I must make do with what I have got to work with and wait till better comes along to improve my situation. I actually rather do enjoy it this way and I really get to know the machine, electronics, techniques etc because I literally have too since I don't really even have anyone to poke for help.
But on the dentist unit / scanner. I wanted to double check to be sure I was not mistaken and it appears I was off by a few microns, litterally just a few though. The scanner claims 10 micron or less scanning accuracy.......
Directly from the spec sheet off their page....
The Cercon eye scans dies and models for crowns, bridges and abutments using a three camera system as well as a laser, which can precisely map up to 16 units per model. Automatic margin detection enables ease of case design. Coping thickness, margins and occlusion can all be adjusted. With a scan time of less than 20 seconds per unit, and a scanning precision of 10 microns or less, even difficult model geometries, such as undercuts, are easily read. The art software also provides the ability to design a crown to full contour and cutback in specific measured amounts.
And info on the milling machine that accompanies it........
Marginal gaps of
50 microns or better are consistently achievable. Marginal integrity has been evaluated to be of the order of 30
microns for crowns and bridges
And......
Fig. 12: Average marginal openings for Cercon restorations are in the 30 micron range
In
and....
Cercon brain expert mills nestable discs for increased efficiency. ... in optimal accuracy and precision with a marginal fit of 25 microns or less,
and an independant lab tests quote.....
Accuracy is measured
by the ability for a bur to achieve the same
position repeatedly, and today’s milling machines
have a repeatability of about 20 microns. The
free linear induction motors that are steered by
magnets (Image 22������������������������������������������������������������
an accuracy of about 2 microns. While this is
one more factor that affects the fit of the final
restoration.
If you really want i can give you the exact references to the links and quotes, but i don't care enough to put in more effort currently. But it appears my initial statement was not inaccurate.
