A little piston comparison fun...
Suprapowaz!(2)
2,870
San Antonio, Tx.
Looking through some of my Mopar parts to get it up and going. I decided to snap some pics of the two pistons and share with you guys.
Adjuster
Yep, look at the stroke too, the Mopar piston and rod combo have at least, if not longer stroke than the 7MGTE setup. (And they don't come apart at high rpm right?)
Also the 7M rod has more meat on the cap end, and even though it's thinner at the pin end, that's fine since the pin is smaller in diameter.
I think this is why the stock 7M rods can handle so much power. They are overbuilt by a pretty good margin.
Do you have weight comparisons for the two pistons and rods? I'd think the Mopar one is at least 1/2 again as heavy, if not more.
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
i did a comparisson of a 7m piston to one of my buddy's from his 350 and his rods were very noticeably less "beefy" also the piston skirts were thinner.
Suprapowaz!(2)
2,870
San Antonio, Tx.
4.25" bore & 3.38" stroke for the Mopar vs. 3.26" bore & 3.58" stroke for the 7mgte. The mopar 383 has a pretty short stroke for the bore size.
I don't have any weight comparison at this time. Yeah, the 7m rods do look beefier for their size.
8,897
zombie said:
how can you possibly see the stroke, there's no cranks in the pic
Because the engine displacement was given in the first pic, along with bore. You do not need a crank picture, just 5th grade math.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Google is your friend.
Mopar 383 with a 4.25" bore has a 3.38" stroke
The info was there and it only took 3 sec to find. Not all info needs to be spoon fed for you to use it.
zombie
72
Midland, Perth, WA, Australia
I wasn't asking for information to be spoon fed to me, I was asking Adjuster how they could see the stroke when all you could see was the piston and the rod
Dirgle
Conjurer of Boost
Pauma Valley, CA
Simple he looked it up. Amazing huh.
