A list of MKIII spring rates OEM, aftermarket and coilover
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
i found this on another Great Supra site www.Supraquebec.com they are a great bunch of people :) and added a bit of my own reaserch
* Stock MKIII
* Front: 461 lb/in
* Rear: 215 lb/in
* Drop: 0
* Stock MKIV
* Front: 430 lb/in
* Rear: 219 lb/in
* Drop: 0
* Suspension Techniques
* Front: 442 lb/in
* Rear: 147-175 lb/in
* Drop: 1.3"
* Eibach
* Front: 343-628 lb/in
* Rear: 126-257 lb/in
* Drop: 1.3" - 1.0"
* Tokico
* Front: 395 lb/in
* Rear: 198 lb/in
* Drop: 1"
* Intrax
* Front: 700 lb/in max
* Rear: 220 lb/in
* Drop: 1.6" - 1.3"
* H&R
* Front: 575 lb/in max
* Rear: 285 lb/in
* Drop: 2"
* R*SR Sport
* Front: 503 lb/in
* Rear: 262 lb/in
* Drop: 1.2" - 0.8"
* R*SR Race
* Front: 677 lb/in
* Rear: 335 lb/in
* Drop: 1.4" - 0.8"
* Whiteline
* Front: ?? lb/in
* Rear: ?? lb/in
* Drop: 1.0
* B+G Suspension
* Front: ?? lb/in
* Rear: ?? lb/in
* Drop: 1.3"
COILOVERS
* Tein Type Flex coilovers
* Front: 671 lb/in
* Rear: 336 lb/in
* Height Adjustment range: F:-0.4",-3.7" R:-0.4",-2.7"
* Ride height Drop: F:-1.7" R:-1.5"
* Tein Type MONO Flex coilovers for JZA70 Supra
* Front: 671 lb/in
* Rear: 336 lb/in
* Height Adjustment range: F:-3.0", -0.6" R:-2.6", -0.6"
* Recomended Height Adjustment range: F:-2.7", -1.4" R:-2.0, -1.4"
* Ride height Drop: F:-1.8" R:-1.6"
* Tein Super Street Dampers w/o upper pillowball mounts
* Front: 895 lb/in
* Rear: 504 lb/in
* Height Adjustment range: F:-1.1",-2.9" R:-0.5",-2.4"
* Ride height Drop: F:-1.8" R:-1.3"
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
aye mate said:
This should be in FAQ! Nice find.
A agree, but I would like to see proof from the manufactures before it goes there. I find it hard to beleave that some like Suspension technics and Tokico would use a softer rate then stock and yet lower the car. Thats asking for something to bottom out IMHO.
BRIAN
187
socal
add the JZA springs aswell, don't they drop the car about .5" compared to 89+ and 1" compared to pre 89...
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'd also like to know what springs are you talking about when you are giving specs for the RS-R's. They have two different steups for MKIII's, RS-R Down springs, and RS-R Race springs.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That's what I was thinking. It seems like RS-R is no longer making products for the MKIII, cuz just about anything they make that a website has no longer actually have them in stock, nor can they get them from the company :(.
JustAnotherVictim
Toyota Supra 87-92 Turbo Race Springs
SKU: 35-T300
Detailed Specifications
Model - Supra
Year - 1987 - 1993
Model Notes - Turbo
Estimated Front Drop - 35mm(1.4in)
Estimated Rear Drop - 20mm(0.8in)
Front Spring Rate - 12.00kg(677lbs)
Rear Spring Rate - 6.00kg(335lbs)
Additional Notes - Fits rubo Model ONLY
yaitsme
Beach Bum
Mar 2, 2006
245
Cheatham County, TN
Zeal's Function-"B6" (listed in one-a those links above) is now replaced by "X" and "Xs"
I just got done running through some questions with an Endless (Zeal's parent co.) representative.
I didn't ask about drop, sorry. But what I did ask about:
"X" has the harsher valving - a street/roadcourse compromise
"Xs" is the street version with "cushy" valving
"X" spingrate: 16front/12rear
"Xs" springrate: 14front/10rear ... (you'll have to do your own conversion, sorry)
"X" adjustment points: 30
"Xs" adjustments: 6
Steel construction standard, Aluminum optional (~$200 extra)
Both have ride height/spring preload independently adjustable
... I'll fire off an email now, & confirm the ride height info if I can.
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Anyone have info on Buddy Club's. I've been looking at them for a while but don't have the funds now (bougtht a trailer instead.)
Looking at zeal as well, just hadn't heard much feedback and there's a big price difference.
