A couple quick questions regarding HG process...
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I wouldn't pull the head back off unless you don't mind buying yet another HG. Composites don't usually like it once torqued down... if you used a tacking agent (ie copper spray or hylomar) forget about reusing that HG completely.
AJ'S 88NA
2,419
Florida
I'm not too sure about taking it off without having to replace the HG again. If it was a MHG yes, but a composite dosen't it have like a layer of sealant that once it's torqued it is a one time thing?
CRE beat me to it:)
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Thanks for telling me that! I had asked that question earlier but no one responded.
I guess I will just keep it on and wait for it to blow if the head is warped...
I was thinkin I might as well take it off since if it does blow its another $85 down the drain for a new HG but if the HG is gonna be ruined if I take it off then I obviously wont.
EDIT: No spray was used.
gaboonviper85
3,236
Northeast Philly
I'm sure someone here has a head gasket to sell pretty cheap...post in the classified....
Or you can wait till you get the milkshake oil and blow all your bearings....
Seriously...take it off while you still have the choice...don't wait till you HAVE to! I know it sucks but atleast you have a choice this time.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Choice? Doesn't sound like much of a choice, Tyler. I'll take it off when I absolutely have to. AKA when the HG blows again.
I just spent $85 on this head gasket. I'm not taking it off and throwing it away. I should have just took $85 in cash and set it on fire. It's going to be used. If it blows then fine, THEN I'll throw it away.
gaboonviper85
3,236
Northeast Philly
please don't....I'd really like to see that car sometime!!!!! Common man...just do it right so you can get it home and I can help you with the turbo motor....dude right there has a gasket for you!
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
It is home. I had it trailered last week.
I'm off to the garage...
...to do something. I'm done with this thread.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Why would he take it apart again just to check for flatness?!?!
Leave it on and if you are paying attention to your car (like you have been) you will know almost as soon as it blows. Dont worry about it until it happens or you have a good week to tear it apart.
Fwiw though, I think *anytime* you do a HG, you should have the head machined/checked, but in your case it's too late.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
suprarx7nut;1049164 said:
Why would he take it apart again just to check for flatness?!?! Leave it on and if you are paying attention to your car (like you have been) you will know almost as soon as it blows. Dont worry about it until it happens or you have a good week to tear it apart.
My thoughts exactly.
Yeah, I figured its only been 2500 miles since I had it cleaned and machined. I didn't think about it warping from not being torqued correctly. Oh well.
CRE
Oct 24, 2005
3,485
Denver, CO
Precisely how loose were the under torqued head bolts? And how hard you been driving the car?
Generally, if you've had it machined and checked the block deck when you swapped it... and you're not going to be bolting on a turbo anytime soon, I'd probably leave it.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
They were not loose, per say. Just not as tight as the others. I used the torque wrench to take all of them off so I dunno. (it was set at 80 when i took them off) And I never really drive it hard.
And I'm leaving it in. End of discussion.
gaboonviper85
3,236
Northeast Philly
elvis has left the building.
TurboFreak;1049006 said:
Haha. Yeah I guess it does. The valves all look ok then?
I think IJ peaced out because I'm not taking the head back off and taking it a machine shop...
Oh well, I don't blame him.
Not at all Ben I was out tuning my car now it actually runs ;)
