Background - fresh re-build, all new vacuum, coolant and oil lines, fresh rebuilt turbo, 90% of the wiring has been inspected and gone through for any needed repairs.
So I finally got the car ready for start-up last night and after a couple of minor issues she started up, no oil leaking, no knocking... off to a good start.
I am running Lexus AFM/550 injectors, AEM WB, with a Neo piggyback controller (not for this forum but I set Neo at 69L/70H, everything below 70 is set to zero compensation). Here are the two issues that I have: (also fyi - no codes reporting)
Running lean - off the gauge at idle >18, if I rev it up a little it will stutter at first as it is starving for fuel, but then will come down to 16-17. By the way running an aeromotive FPR set at 35 psi with no vacuum, also tried 40 made a little difference.
If i compensate with the Neo at idle it will come down to the 14.8 with 50% compensation...
2nd issue -
Do not think they are related. I have a spot in the throttle that the engine acts like it is hitting a fuel cut or something. Let me explain, it is right around 3.5% throttle (so just feathering) at a standstill that is about 2000rpm, but is linked to throttle % not rpm, as tested on the road. If I am just sitting and try to hold it right at 3.5% it will act like it is going to die, drops to 800-1000 rpm then jumps back up to 2000, it will do this every 1 second or so continuously.
The thought I had was the TPS, but I set it per the TRSM, also I would think if it were that it would not report the % position correctly to the Neo, but then it appears the is just an open/close switch for idle, would that be different reaction if not set perfectly in position? Maybe TPS has nothing to so with it...
If you could offer any suggestions on either one / or both issues I would GREATLY appreciate it, it as been off the road since last November so very anxious to get the wrinkles ironed out...
Thanks
2nd issue -
Thanks
