A/C after 2jz swap
tissimo
Stock is boring :(
Melbourne, FL
what do you mean?
I had fal fans on my 2jz swap and it was cold.. I assume clutch fan and the 2 stock fans would pull as much air....
jugodegolf
Phoenix,AZ, United States
tissimo said:
what do you mean?
the 2 stock fans don't fit. IC pipes go there currently.
tissimo
Stock is boring :(
Melbourne, FL
ahh.. i see what you're saying.. get a stock fan shroud, block off the stock fan holes in the shroud, and put the stock or an aftermarket pusher on the condenser.. it will work good then.. you'll be suprized how much just the shroud will do
jugodegolf
Shroud is on order. not sure what u mean w/ pusher on the condeser but adding to my list of to do's.
Thanks Tissimo
tissimo
Stock is boring :(
Melbourne, FL
90% of most stock turbo auto cars have a pusher fan on the condenser, though I've seen some manual cars have it. that plus a good condition clutch fan should work fairly well..
you can kinda see it in this pic a little
