Turbo. Targa. Life. said:Worst...analogy...EVAR.
When you lick your finger, the air isn't cooler that's hitting your finger, it's cooling the spit ON your finger. When your finger is dry, you have your body temp (around 97*) going up against the wind. When you lick your finger, you have spit, which has undoubtedly cooled down at least 20* by the time you raise your finger, being cooled by the wind. It's as simple as--hold an ice cube to your finger, it melts. Wet your finger, then hold an ice cube to it--it sticks. It's becuse the water on your finger cools and bonds with your skin.
Someone correct me if I'm way off base here![]()
Wikipidia said:The thermal motion of a molecule of liquid must be sufficient to overcome the surface tension and evaporate, that is, its kinetic energy must exceed the work function of cohesion at the surface. Evaporation therefore, proceeds more quickly at higher temperature, at higher flow rates between the gaseous and liquid phase and in liquids with lower surface tension (i.e. higher vapor pressure). Since only a small proportion of the molecules are located near the surface and are moving in the proper direction to escape at any given instant, the rate of evaporation is limited. Also, as the faster-moving molecules escape, the remaining molecules have lower average kinetic energy, and the temperature of the liquid thus decreases. This phenomenon is also called evaporative cooling. This is the reason that evaporating sweat cools the human body.
Maximum Boost by Corky Bell said:The air/air unit will generally have greater simplicity, greater thermal efficiency at high speeds, greater reliabilaty, lower maintenance, and lower cost. The air/water unit will generally have better thermal efficiency at low speeds, better throtle responce when a mass-flowmeter-equiped EFI system is present, lower boost pressure loss, and less compresor surge.
Maximum Boost by Corky Bell said:Although complex, the water based ic enjoys the one teriffic advantage of the far greater (forteenfold) heat transfer coefficient between water and aluminum than air and aluminum.
souprat said:i'll be the one to correct you! wind does not, and cannot cool things by simply flowing, if anything it heats things up(fricton). wind is just air, therefore the wind is at the same temp as the air and by just blowing on your wet finger you are not cooling your finger down by the flowing of air over you finger, but by the evaporaion of the spit off your finger.
air to water ic's are the shit. they can be made small because of the cooling abilatys of water, low pressure drops, and high efficency. and if yoi still dont believe me, then yo might consider that IJ is running a PWR air to water ic. circulating the water with a electric pump to a pair of oil coolers i believe.
Turbo. Targa. Life. said:Hmm that does make sense!! But that was still the worst analogy ever!!![]()
