90 Turbo 2jz-ge-T/R154 build
gixxer750
2jzget comingsoon!
Mississippi
So, Im a supra owner again.... Picked up a grey on grey 1990 NA hardtop 90K mile chassis.... that is super clean. 7m is of course, toast... So, doing an NA-T 2jz in it. So, here is my build thread...
gixxer750
2jzget comingsoon!
Mississippi
Well, initially I was going to do a 7m turbo harness, but I have an NA 2jz harness, and I have the original NA harness from the car. I've decided I'm going to build a hybrid 2jz-Ge harness that plugs in the car, add wires for three waste spark coils, and use the factory distributor wiring to run TT cam and crank sensors. Ill weld a cam sensor bung on the head, and go TT cams, and a TT oil pump and crank trigger wheel. I am using AEM for engine management anyway. I picked up a precision 74mm with a GT wheel for 200 bucks. I also managed to score a 2jz-GE from an SC300, complete at pull a part, from a wrecked car with about 100K miles. I will be putting a new TT rotating assembly in the block that I picked up cheap. I have my R154 now, ACT stage 3 extreme duty clutch... I still need a 1jz flywheel and bellhousing though. 7m is stripped out of the car, and unnecessary stuff is already gone. So, progress is being made for sure.
Doat
2,599
Houston, TX
Subbed, I plan on doing this very swap in my MK3 with a 2jzge coming from a 98 SC300, which apparently has coils instead of a distributor if i am not mistaken so I am bit confused on how that is going to work out. I am going to get a new wiring harness from Tweak'd to make life easier instead of using two old harnesses mixed together lol. What are your hp goals?
gixxer750
2jzget comingsoon!
Mississippi
So, I've got an 80K mile R154, I ordered my 1jz bellhousing and flywheel from my favorite local toyota dealer (576 for both of them). I picked up a brand new TT rotating assembly from a guy who bought a new shortblock and went 3.4 stroker, so I have a brand new 0 miles crank, rods, pistons, rings, bearings, thrust washer and a new stock TT head gasket. I have to make or locate a cam sensor bung to weld on the cylinder head now. I also grabbed a stock TT intake, to mate up to the GE runners. Picking up my turbo in a few days, a nice 76 billet precision...
Then, I need to sell some parts for more funding... LOL. Wishing this R154 swap I've got would sell.
