So as a few of you know, i'm a former supra owner who no longer has one, but i have a few other interesting projects heres one:
90 Subaru Loyale Wagon. Cars stock right now, only had it a couple weeks, but this next week should be fun. bought it for 200 bucks
Engine:
EA82 TBI 1.8L (throttle body injection, one injector for the entire engine)
its got 154k hard miles. when i got it it was running off two cylinders, had half a quart of oil ( later found out it was conola oil!)
so its got new sprak plugs, cap rotor, wires. oil flush and change with filter.
now it runs great, turns over the instant i turn the key, but its got no compression. does 0-60 in 49 sec! oh and an orbital 1200CCA battery
Drive line:
FWD/AWD button controlled, bend driveshaft from a bad 7' landing.
thats the only thing interesting right now. but this week im doing a 2" lift, 4x140mm lug to 6x5.5" lug conversion. toyota 15x7's. so ill be going from a 175/70R13 to a 225/70R15.
then this spring im putting in an EJ22T. its a block from a legacy and heads and turbo off an STI. so ill be going from a 35whp single cam 1.8L to a 250whp quad cam 2.2T. i need more power to turn the bigger tires lol and after the engine come the 6" lift 30" super swampers, and an exterior roll cage. ill update as i go.
Engine:
Drive line:
