I also adjusted the CPS to 10* BTDC. It was already pretty close but I didn't know for sure and I was hoping it might help my rough idle. No luck though so I'm still working towards figuring that out. I'm just now realizing I should be posting more pictures of this stuff!
Another thing I've been working on is getting the factory electric fan relays to run my Mishimoto fans. I got rid of the mechanical fan for this shroud/fan combo and planned on using a Painless F5 controller I've had lying around for a while. After doing some research online I decided to give the oem wiring a chance first. I figured it was already there and I'd much rather use the existing electrical system than add more complexity to it. The only hesitation I had was not really knowing what temperature the oem fan switch turned on. So I cut off the connectors and wired the fans in. I grounded the connector going to the aux fan temp switch and both fans turned on! "Great!", I thought. So I started the car and let it warm up... and warm up some more... and hotter and hotter.. eventually got to the point where I wasn't comfortable with the temp and turned it off. I still don't know what temp it's set at but I could've just had a bad switch I guess? So anyway, I found a 200* switch from Summit for about $20 that fits into the thermostat housing. Installed it, put a spade connector on the wire harness and connected it to the new temp switch. I still need to test it to make sure it turns on at the right temp but I'm pretty confident this setup will work!
While I'm at it, the other temp switch I removed is for the a/c fans. I'm assuming that switch just turned on the 3rd electric fan that was between the radiator and condenser right? So if I don't have that fan I don't need the switch hooked up? The wire that went to the switch is broken anyway so I'm hoping I don't need it and can just leave it unhooked... someone please correct me if I'm wrong though.
