Great idea for adding the lights for the corner markers. I might just have to use your way of opening them.
89TurboPC;773093 said:Into the light housing.
They actually work . The picture is a little angle cuz I can't stand straight at the light as you know why. The brake/marker is DIMMED as it will be marker brightness.
With the lens on (still on marker brightness).
Oh yeah, with full brightness on (brake)
Now I need to find a way to mount the board into the housing either permanently or semi-permanent.
89TurboPC;782186 said:My project is basically completed. The only way you can tell whether it is worth the effort is to see it in person. Pictures can't show it enough.
This is how I mount the marker/brake board. Basically, I make 4 little clips and insert into the holes where the "legs" for the diffuser used to be and bent it over to the board. Kind of similar to picture frame mounting.
Close up of the mount.
In the car and how it is compare to the filament bulbs. Marker brightness.
Brake or full brightness. At night, it is insanely bright.
Well, this project cost me an extra amplifier ... While I have the light out in the house, it was raining really hard for 1/2 hr one night. The result is that there was about 2 gallons of water inside the spare tire area (even I have a car cover on). I didn't know there was water in there at first because the back cover carpet isn't wet. I have the amp mount under the cover next to the spare tire. When I have the radio on and notice that there isn't any bass coming out from the back, I check the amp and sure the fuse blew. I knew something isn't right because that same fuse was been there for at least 10 years. I replace a lower rating fuse turn it on again. The fuse isn't blew but Genies magically came out of the amp. I yank the fuse and cut off power to the amp. I start to notice that water in the spare tire place. Took the amp out and it is fill with water. It's really suck. The amp was given to me from a friend who burned it from overpower/distortion. I fixed the transistor and it work fine since for at least 15 years moving between my 2 supras. It's an OLD SCHOOL Kenwood KAC-821.
Supra469;1180186 said:Question for you TurboPC,
The LEDs on the Infiniti FX & Highlander Hybrids seem to be nice and big could larger LEDs like those be purchased and used on a project like yours?
Thanks.
89TurboPC;1180553 said:Sure why not. The only problem I can see is the specification for those LED and the footprint for PCB. If you know the spec for the LED, you can adjust the circuit (resistor size) to work with those LED.
Beals;2063412 said:Had to bump this thread, some great info it should be a sticky! I plan to do something like this in the near future! I have to ask are you the one ebay selling this mod?
