SuprA70;959706 said:Maybe you can cut it and fit a pre89 grille? Someone step up and experiment on their Supra
Actually the openings are different sizes. You'd have to do a lot of tweaking on the pre89 grille to make it work.
One thing I would have loved to do is add the cross pieces from the MkIV nose. They have a piece in their nose that goes up the middle and has a horizontal cross piece as well. Unfortunately, this piece is too small as well.
Bracing the nose is actually easier than it sounds. Most people just don't think about doing it.
I agree though that most people don't "fix" the nose properly after they cut out the grille and that does look terrible. But I do so love having that HUGE opening (bigger than the GRacer or the pre89 - wider than the MAXX). And without the fins there is more flow - there has to be since there is less "stuff" in the way.
Also, modifying the stock nose you keep the perfect lines of the car - rather than bolting some other nose on the car that looks like you simply bolted on a new nose.
