89 7mge revving problems
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
I have an 89 cressida and im having a problem where it wont rev past 4k i have no check engine lights nothing i have been working on it for a few weeks now trying to figure out what is wrong but cant find whats wrong. I hoping some one on here can help me out. Thinks i have check wires cap rotor plugs and wires, tps, afm, fuel filter, everything was good and with in spec.
supraduper
126
merrimack nh
the air gap is the space between the magnetic pickup and the reluctor.. i dont know off hand what the spec is, but its in the tsrm i am sure....
you will need a set of non magnetic feeler gauges..
and are you sure you have propper fuel pressure....
fuel would be the most likely culprit..
but with an old worn out distributor... the faster the reluctor spins and the increase in space to the pick-up.. the harder it would be for the pickup to "sense" the rotation...
its a thought
ricerkid
57
St. Louis
it sounds like the maf sensor is kaput to me. I had the exact same problem with my 7mge; it wasn't throwing any codes. Check the resistance on your maf sensor. I bought a remanufactured one at autozone for $180 which isn't too bad in my opinion, also your local breakers yard might have one.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Well, when i bought a re-manned distributor for my old worn slap out one, it wouldn't let me rev past 3000 rpm and would bounce like rev limiter. So i just put old one back in and it worked fine. same timing and everything. I was about to say it was your mas or your TPS.
cuel
1,536
Baytown, Texas
Might check your fuel filter. It gets plugged up enough, you won't get enough fuel. Air filter as well, but it would have to be REALLY bad. K&N filters that don't get cleaned are bad about that...
