shaeff;1489477 said:Updates? C'mon, I'm living vicariously through this swap until I can do my own hopefully this spring!
Huh. IIRC, you're using the Cressida pan/sump, right? That was my plan as well. Maybe I'll make a custom pan. We'll see... I'm looking forward to this swap being done!bmoss85;1489628 said:I'm wating on the harness to come back. The guy that owns the truck wanted to go ahead and have a custom harness made.
I really don't like how the engine sits at all, it's slightly tilted towards the rear of the truck. I know it from moving the motor mounts further forward on the block. The oil pan is also alot closer the front diff than I care for.
He was asking me the other day about putting new cab since his has some rust on the floor boards.
I'm also going to have to modify the hks down pipe but thats no biggie. I think we are going to dump the exhaust right after the passenger door instead of running all the way to the back.
Hopefully I will have some better updates soon.
NashMan;1489662 said:i simply would never do this swap only one reson toy shit is shit
in less you had fj80 axles or 1 tons the axle will take it but not the diff's then just chip and die
the 7mte will just eat them alive
but if you keep them open and no lockers and no bigger then 33 you might get awau with it mabye pending on how hard you on your shit
shaeff;1489729 said:Huh. IIRC, you're using the Cressida pan/sump, right? That was my plan as well. Maybe I'll make a custom pan. We'll see... I'm looking forward to this swap being done!
I disagree. The 8" rear diff is plenty stout enough for the 7M. The front is a 7.5" just like our Supra rear ends. As long as you're not beating the living piss out of it in 4WD, the diffs should be fine. Especially if a SAS is in his future.
Another option is V6 diffs. (I've got a rear V6 third in my Pickup w/ a Tru-Trac)- the V6 diffs have stronger housings, and are four pinion as opposed to the two pinion 4cylinder diffs.
I plan on running 35's w/ my 7mgte, locked rear and tru-trac front.
NashMan;1522291 said:well i blown 5 diff in my v6 3 slow see the diff it self ok ish it's the ring gear that dies i broke like 4 of them and destroyed carrie as well and twisted a shaft and bent one
there people that wheel (ME) and there people that don't (YOU)
and if you run detiot the if the ring gear doe snot fail and break shaft you grenade the diff form the shock load
