86.5 and pillowball mounts
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
I did a search and found no complete answer to this. I have a 86.5 supra and I have front and back bilstiens from a 92 jza. Now heres the question, do I need pillowball mounts for the front AND back or just the front? Ive been told some conflicting things about this and need help. Thanks:1zhelp:
supra90turbo
shaeff is FTMFW!
32
MA, 01440
you do not "NEED" them per se, rather it would be better to have them.
you can use the stock mounts unless the JZA bilsteins are different than regular bilsteins.
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
So then I would need to use them front and back? Cause I woulndt want to do some half ass job. Whatever will help the car drive better is what I will do, I dont want to skimp on the mounts then have something break cause I didnt get them.
I'm not quite getting the need for pillowball mounts at all here.....
I'm assuming you're talking about ballbearing upper spring mounts, Our cars are double A arm front and rear so there aren't any turning loads like in a McStrut front end.
