Ok, i got another 7mgte that i want to put in to replace my old one. I'm taking out the motor alone instead of motor and trans at the same time... so far, this is where i've gotton. I unbolted all the bolts, hoses, mounts, and EVERYTHING ELSE POSSIBLE like the a/c stuff, p/s stuff... the motor is basically ready to come out right? well heres the problem i'm having... I figured like the rest of the cars i've worked with, it should just slide off the shaft of the transmission. But as i'm trying to slide it out, it doesnt come out... it sorta looks like its coming out.. but something is holding it in?? but no bolts at all are on the transmission to the block. I know it shouldn't take this long for me and my friend to take this motor out... but i've never pulled out a supra motor before... so i don't know whats holding the motor to the transmission? I looked at the manual and it says Slightly lift the engine, and i should be able to slide it out.. but maybe the shaft is binding on the clutch?? i dunno.. can you guys help me out? I can describe it more if needed. thanks again guys
Josh
Josh
